This introductory seminar provides a basic overview of the capabilities, concepts, resources, services, and benefits available for the Vectorworks user to get started. This session explains the user interface and demonstrates how to use tools and menu commands to create and convert objects. Learn about classes, design layers, viewports, renderings, and sheet layers to present and annotate drawings and publish your work.
The Rendering in Vectorworks overview will introduce you to the key techniques needed for successful rendering. From configuring Renderworks Cameras and applying basic render modes to lighting and texturing, this guide will give a good base for exploring the power and capabilities of Renderworks.
Video
All Industries
2 Hours 30 Minutes
Beginner
LEARNING OBJECTIVES
  1. Explore the rendering capabilities of Vectorworks software.
  2. Learn how to use Renderworks Cameras to create rendered views.
  3. Apply lighting, texturing, and render modes.
  4. Explore solar animations, panoramas, web view, and other presentation techniques.
Fundamentals, Architect, Landmark, Spotlight, and Designer
In the Vision guide, we will begin to explore using Vision for previsualization. In addition, we will show how to properly configure lighting devices in Vectorworks, for export to Vision. You will be introduced to dmx, patching, fixture modes, as well as configuring a custom lighting device in Vectorworks, for use in Vision.
Video
Entertainment
20 Minutes
Beginner
LEARNING OBJECTIVES
  1. Explore the use of Vision for previsualization.
  2. Understand the basics of DMX.
  3. Explore how to assign fixture modes and patch devices.
  4. Learn how to use emissives in Vision.
Vision
The BIM - Architectural guide will take you through the use of the core architectural tools. As well as, introduce you to key concepts ranging from the uses for classes and layers, to symbol types and publishing your projects.
Video
Buildings
1 Hour 30 Minutes
Beginner
LEARNING OBJECTIVES
  1. Explore Commonly Used Building Tools
  2. Learn How to Use Dimension Tools
  3. Observe the Creation Process of Viewports
  4. Discover Useful Presentation Techniques
This course is designed to introduce many of the Landmark design tools and workflows. Starting with Plants, you will learn how to use the Plant tool and configure Plant Style settings and graphics. In addition, we will take a look at the Hardscape and Landscape Area tools. We will also, begin to explore site modeling in Vectorworks software.
Video
Landscapes
3 Hours
Beginner
LEARNING OBJECTIVES
  1. Learn how to place and edit plants.
  2. Understand how to create hardscapes and configure their settings.
  3. Explore the creation and use of Landscape Areas.
  4. Learn how to create and modify a Site Model.
Landmark and Designer
In this overview, you will explore Irrigation Design in Vectorworks software. For this guide, we asked one of our users, Bryan D. Goff, to demonstrate how to use the various irrigation tools available, to create effective irrigation designs. You will be introduced to all of the irrigation tools and their settings.
Video
Landscapes
1 Hour
Beginner
LEARNING OBJECTIVES
  1. Explore the use of the irrigation tool set in Vectorworks Landmark.
  2. Learn how to place outlets, pipe, valves, and drip lines.
  3. Practice creating an irrigation network.
  4. Learn how to analyze an irrigation network.
In this course, we will introduce you to commonly used tools and workflows in Vectorworks Spotlight, for entertainment design. You will explore Lighting, Rigging, Audio, and Video tools in Vectorworks Spotlight. In addition, we will explore preparing a project for export to Vectorworks Vision as well as review the capabilities of the various Cabling tools.
Video
Entertainment
2 Hours
Beginner
LEARNING OBJECTIVES
  1. Explore the core Vectorworks Spotlight tools and commands.
  2. Learn how to create staging, seating, and soft good objects.
  3. Learn how to place, position, and number lighting devices.
  4. Explore the audio and video tools and learn how to place cables using the cabling tools.
Spotlight and Designer
