This tutorial outlines the interrelationships between levels, layers, and stories, as well as examines how to create and edit both walls styles and slab styles, which leads to greater change management in your building information model.
Note: This course is intended for Vectorworks 2018 and earlier. An updated course is available for newer versions.
LEARNING OBJECTIVES
- Explore the Concept and Use of Layers, Levels, and Stories
- Create a Story Structure
- Setup Story Levels
- Explore Wall and Slab Styles
- Create a Wall Style
NOTE: This course describes a legacy workflow, that is no longer recommend for Vectorworks versions 2019 or newer.
In this course you will explore the creation and use of a two-way finish schedule.
LEARNING OBJECTIVES
- Learn key terminology
- Explore how to make a room finishes schedule two-way
- Learn how to create and edit a worksheet
