THE DOOR TOOL SETTINGS
Completion requirements
Go through the activity to the end
BY INSTANCE, BY STYLE, BY CATALOGUE
Unstyled Doors
Each placement of an unstyled door in a document is unique, and as such, all parameters for unstyled doors are editable 'by instance'. This means every instance of an unstyled door is an opportunity to edit its parameters for its specific situation. This allows for maximum flexibility per door, but it is inefficient for editing parameters whose values are intended to repeat across multiple doors in a document.
You can access an unstyled door's settings before placement by clicking the Door Tool Preferences icon (located in the mode bar, just above the top left of the drawing window).
After an unstyled door has been placed, its parameters can be accessed directly via the Object Info palette or by clicking the Settings button.
A styled door can be converted to an unstyled door before placement by clicking the Use Style dropdown at the top left of the dialogue and then clicking the Unstyled button at the top center of the Resource popover. After a styled door has been placed, it may be converted to an unstyled door via the Object Info palette by clicking the Style dropdown and then clicking Convert to Unstyled.
Styled Doors
Styled doors can have some parameters set to 'by style' and some set to 'by instance'. This allows you to easily edit values shared by multiple doors of the same style (parameters set to 'by style') while also allowing some flexibility to adjust specific values for individual doors (parameters set to 'by instance').
As mentioned above, you can access an unstyled door's settings before placement via the Door Tool Preferences icon, but for a styled door, you can only adjust the values of parameters set to 'by instance'. New values entered for 'by instance' parameters will become the default values for new placements of the door style in the document (until they are changed again).
After the styled door has been placed, most 'by instance' parameters can be accessed directly via the Object Info palette. (Tip: Click the Hide style parameters checkbox to see only the 'by instance' parameters available for editing.)
If you wish to change the 'by style' parameters or the default values for the 'by instance' parameters, you will need to edit the door style. There are two ways to do this.
- Locate the door style in the Resource Manager
- Right-click the thumbnail and select Edit
- Right-click on an instance of the door style in the model
- Select Edit Plug-in Style...
- Right-click on the door in your model
- Select New Plug-in Style from Unstyled Plug-in...
Catalogue Doors
Catalogue doors are styled doors whose values derive from a manufacturer's catalogue. Several catalogues ship with Vectorworks. This allows you to select doors using the manufacturers' values for parameters.
You can access a catalogue door's settings before placement via the Door Tool Preferences icon. Like a styled door, you can only adjust the values for parameters set to 'by instance'. Once new values are entered, they will become the default for new placements of the door style in the document.
After placing the door, the 'by instance' parameters are editable via the Object Info palette.
You will need to edit the door style if you wish to change the catalogue door's 'by style' parameters or the default values for its 'by instance' parameters. Again, there are two ways to do this.
Below are the icons indicating which parameters are set to 'by style', 'by instance', and 'by catalogue'.
