THE DOOR TOOL SETTINGS
Completion requirements
Go through the activity to the end
DOOR SETTINGS, DOOR STYLE
Unstyled Doors
For unstyled doors, the features at the top of the Door Settings dialogue follow.
Use Style: A dropdown to access the Resource popover and select a styled door.
Styled and Catalogue Doors
The features at the top of the Door Style dialogue follow. These appear for styled and catalogue doors.
Style Name field: This field contains the generic name of the door style. You can edit the existing name or enter a new name to make identifying the style easier.
By Style/By Instance toggle: Click the icon to change the Select from Catalogue parameter between 'by style' and 'by instance' settings. This parameter is seen in the Object Info palette below the Style dropdown when a styled or catalogue door is selected.
Catalogue toggle:
Click to access the list browser and choose other models associated with the selected door catalogue.
Catalogue button: Click this button at the top right of the dialogue to select (attach) a different manufacturer catalogue or to discontinue (detach) the use of the manufacturers' catalogues.
Navigation panel: This column of tabs at the left of the dialogue is used to switch between different groups of door settings. Selecting a tab will make the parameters associated with that tab appear in the middle of the dialogue.
3D Preview: Seen at the top right of the dialogue, this heading includes dropdowns for selecting the view, rendering, and detail level of the door's 3D preview.
Top/Plan Preview: Just below 3D Preview is the Top/Plan Preview heading, which contains a dropdown for setting the detail level for the door's Top/Plan Preview.
ⓘ Some door components may not display when Low detail is selected. The default is Medium.
