THE DOOR TOOL SETTINGS
Completion requirements
Go through the activity to the end
ID TAG
The ID Tag pane contains parameters for determining how a door is identified and reported in keys, schedules, and legends. We will briefly survey some of its features, but take advantage of the Help page for a full breakdown.
ⓘ Since Data Tags were introduced, many of the ID Tag parameters are now considered legacy features.
Key Features
Include on schedule: This parameter is critical if you use the preformatted reports because only doors with this checked will appear in those.
This checkbox is sometimes used to distinguish between existing doors (not checked) and new doors (checked) in a report, though there are other ways to achieve this.
ⓘ If you use Data Tags to key doors, you may only need to enter values for the ID Prefix, ID Label, and ID Suffix fields, as those values are most likely reported in the tag.
Still, if you prefer to use the door's built-in tag—that is, when the Show tag in 2D checkbox is checked—you can use its accompanying parameters to control how the ID tag looks and functions.
