THE DOOR TOOL SETTINGS
Completion requirements
Go through the activity to the end
LIGHTS (US), SIDELIGHTS (UK)
The Lights (US) or Sidelights (UK) pane contains a door's light/sidelight parameters. We will briefly examine some of its key features, but for a full breakdown of all the fields, please visit the Help page.
Key Features
Include sidelights: Check to include sidelights, and if you only want a sidelight on one side, set the opposite side's Width value to 0" (0mm).
ⓘ If you want a sidelight that is less than the full height of the door, you must place a separate window object next to the door instead of using the door's sidelight function. This alternative has the added benefit of making all the window's settings and options available for your sidelight.
