THE DOOR TOOL SETTINGS
Completion requirements
Go through the activity to the end
THRESHOLD
The Threshold pane contains parameters for the door's threshold. We will look at a few of its key features, but for a full breakdown of all fields, please visit the Help page.
Key Features
Include threshold: Check to include a door threshold, but remember that the added threshold dimensions must be accounted for in other door dimension fields. For example, one critical instance is the Height field on the General pane. If the threshold thickness value is one inch, then one inch must be added to the door's height.
ⓘ In the 2D Visualisation pane, you can assign the threshold to a dedicated class. This will allow you to hide the threshold in plan views while still being able to report the threshold in your door schedule.
