LOCATE YOUR PROJECT
  Working with X and Y Coordinates
Regardless of your workflow, you will want your document origins to be somewhere sensible, even if only to ensure you are on your drawing board!
Explore the options for setting up your X and Y coordinates in this session.
  DWG Import Location Options
The first time many people encounter problems with origins, it is often the result of importing a DWG from others.
This session takes you through the DWG import options.
  Georeferencing with Known Coordinates
If you are working on a georeferenced project, you should be given the coordinate system and coordinates that everyone will be using to align their drawings.
In this session, we will look at setting up a georeferenced file with known coordinates.
  Setting the Geolocation of a Project
Sometimes, you are the one who must decide how to geolocate a file.
In this session, we will look at determining the geolocation of a project.
