THE WINDOW TOOL SETTINGS
Completion requirements
Go through the activity to the end
SILL
The Sill pane contains a dropdown for selecting the sill type and several fields associated with the sill's dimensions.
We will look at some of the key features of this pane, but for a full breakdown of all its fields, please visit the Help page.
Key Features
Include sill: Check this box to add a sill and activate its parameters.
Sill Type: Choose a sill type (Timber, Masonry, or Brick) and enter values in the numbered fields corresponding to the respective diagrams.
ⓘ The default values may make the sill appear to be facing the wrong way. Check the sill's slope in a 3D view. If it is facing the wrong direction, you can select the wall and click Reverse Sides in the Object Info palette. Remember, the wall's left side is the outside of the wall.
