THE WINDOW TOOL SETTINGS
Completion requirements
Go through the activity to the end
LINTEL
The Lintel pane contains parameters for the window's lintel. We'll take a quick look at a few key features of this pane below, but for a full breakdown of all the fields in the Lintel pane, you can visit the Help page.
Key Features
Include lintel: When checked, the lintel will take the top shape of the window, and the diagram will change to correspond to your selection.
Interior Protrusion and Exterior Protrusion: To have the lintel appear on only one side of the window opening, enter a zero value for the other side.
Note: You can enter values into the Angle or Drop fields to specify the end terminations of the lintel. Making the Drop value the same height as your window will create a surround effect.
