DATA
The Data pane contains a list browser for entering values into an array of default and user-defined fields for reporting purposes. Some fields may be pre-populated with values pulled from the manufacturer's catalogue when such a window is used. Furthermore, these values may be mapped using the Data Manager to reduce duplicating inputs. For a full breakdown of the fields in the Data pane — as well as for additional information on the Data Manager — please visit the Help page.
Vectorworks
Help
ⓘ For BIM: The Reference field of Pset_WindowCommon will pull the value from the window's Style Name if it has one, User Field 10 if it does not, or default to W-1 if neither applies. These values can be changed in the Data Manager or manually edited per window in the Object Info palette.
You have completed 100% of the lesson
100%
