Introduction to Referencing
Completion requirements
View
Go through the activity to the end
Design Layer Viewport Referencing
Design Layer Viewport Referencing works by creating a viewport which looks from the target file to a source file (or files). For example, if you were designing a residential street, several people could be working on different house types to be used in the street. There would then be the street itself in a separate file, referencing all these house types into one master document which can also be worked on by another person.
Click Next to start the exercise.
Before starting this exercise, you will need a source file with layers, classes and objects as well as a target file. Both files need to be saved.
