Master the key skills required to be successful in Vectorworks by earning your Vectorworks Core Associate Certification. This learning path contains over 170 courses and exercises that will equip you with the essential knowledge to operate Vectorworks with confidence. The Vectorworks Core Associate Certification learning path and exam are available free for a limited time.
To earn your certification, you must successfully pass the certification exam, with a score of 80% or higher. There are no restrictions on how many times you can retake the exam. If you do not pass on your first attempt, we recommend reviewing the certification courses and trying again. By passing the Vectorworks Core Certification exam and receiving this certification you will demonstrate to employers and clients that you are competent in core Vectorworks tools, commands, and workflows.
We highly recommend going through all of the courses in this learning path before taking the exam. However, we know there are many experienced Vectorworks users out there. If you feel you have already mastered the subjects covered in this learning path, you can skip directly to the exam.
Your certification is valid for 3 years after successfully passing the exam. Once you pass the exam, you will be able to download and display your personal Vectorworks Core Associate certificate and seal. You will be notified 6 months before your certification expires and with updates for continuing your education.
Welcome to the Vectorworks Core Certification Program!
Con la versione 2023 di Spotlight potremo sfruttare un flusso di lavoro di rigging più coerente e snello, con le migliorie all'inserimento dei bridle, la nuova gestione dei tralicci incrociati e l'evoluzione dello strumento Paranco
In Spotlight 2023 possiamo effettuare una progettazione dei cablaggi ancora più rapida, con la nuova Vista Proprietà e le sue rinnovate opzioni di ordinamento e filtraggio, le migliorie al Grafico dispositivi, la nuova gestione di fixture, utilizzatori e distributori e l'esportazione potenziata tramite foglio elettronico.
Uno Spotlight interamente rinnovato, con le migliorie agli apparecchi illuminazione, il nuovo Strumento Ringhiera/Recinzione, il potenziamento dell’oggetto Videocamera, le specifiche della Platea di poltrone, l’orientamento 3D dei carichi e numerosi altri aggiornamenti.
Learning Objectives
Il nuovo Strumento Magneti di Vectorworks Spotlight rivoluziona completamente il sistema di connessione dei tralicci, rendendolo ancora più semplice e preciso.
Learning Objectives
Vectorworksの3Dの基礎を習得するコースです。基本的な2D操作を理解した方向けのコースです。
PART1では、基本的な3Dのコマンドを使用して2D図形から3D図形を生成し、さらに3D図形に加工や編集をする方法を習得します。
PART2では、より幅広い形状を表現するためのツールやコマンドを理解します。さらに、複雑な曲面構成により自由度の高いモデリングを可能にする「サブディビジョン」の基本操作を理解するためのトレーニングが含まれます。
