As a valued member of the Vectorworks community, we’re pleased to welcome you to this exploration file, provided by Vectorworks. This sample has been made possible through the generous support of Studio Partington who have contributed the original project concept, and Scope Surveys who have kindly provided the surveyed drawings used in this model. Their collaboration enables a realistic architectural context for demonstrating advanced Vectorworks workflows.
This sample file focuses on Phasing, a comprehensive time-based system in Vectorworks for managing renovation and multiphase projects. Phasing allows tracking objects through multiple stages — such as existing conditions, demolition, and new construction — and automatic assignment of the appropriate status to each object.
To start exploring, we recommend reviewing the Saved Views and Sheet Layers in the Navigation palette, where you can see Phasing in action across different stages of the project.
This file introduces the power of Showcase to achieve real-time previsualization directly inside Vectorworks Spotlight, allowing you to test run the show, experiment, and edit to your satisfaction.
This Lakehouse Landscape project provides a BIM workflow demonstration, showing the process of modelling residential landscape using Vectorworks Landmark. The focus rests firmly on the BIM process and explores the progress of the model through digital work stages and Level of Information Need, all the while referencing back to the UK BIM Framework and ISO19650 relevant standards.
Parametric tools, intelligent objects, data handling and creating associated views from the BIM model are demonstrated as best practice use, to streamline and optimise the design and modelling process while ensuring the maximum quality and consistency of delivery information.)
This file features scenery on a revolving platform. The lighting is primarily conventionally driven. The file includes a DMX recording for playback, and some of the scenery is also controlled by DMX. This helps demonstrate Showcase in a theatrical environment.
As a valued member of the Vectorworks Community, we would like to welcome you to this exploration file provided by Vectorworks UK, a subsidiary of Vectorworks Inc. This Commercial Courtyard project provides a BIM workflow demonstration, showing the process of modelling commercial landscape using Vectorworks Landmark and Vectorworks Architect (existing building). The focus rests firmly on the BIM process and explores the progress of the model through digital work stages.
This sample file of a high-end Residential install showcases the core functionality of ConnectCAD for AV Systems Integrators. It provides a baseline workflow while demonstrating customization options. The ConnectCAD add-on for Spotlight includes tools tailored specifically for the AV industry, helping installers streamline workflows.
This is a residential interiors project that shows a portion of a house. This project includes a poker room, stair, karaoke stage, wet bar, powder room, home theater, and audio/visual room. This file is a 3D model with textures, lights, and parametric objects. It documents several common interior design workflows, including a mood board, plans, reflected ceiling plans, finish plans, interior elevations and renderings. Several annotation and reporting tools are used to create more efficient workflows, such as data tags, graphic legends, and worksheets. It also contains custom parametric objects created using Marionette.
Dover Dam is a residential project located on an existing farm. The project is a 3D BIM model that includes stories, a site with modifiers, hardscapes, marionette objects, interior furnishings, and light fixtures in addition to traditional building objects organized by styles. The documentation makes use of viewport styles, smart markers, data tags, dimensions, callouts, 2D annotation tools, grid lines, elevation benchmarks, graphic legends, worksheets, title blocks, class overrides, and data visualizations specifically to modify and enhance drawings.
The Grotto is a penthouse/rooftop private club project.
Designed on a historic building in Chicago. It incorporates biophilia principles.
Chicago has 509 vegetated roofs with 5,564,000 square feet green roof coverage. Initiatives began in 2001 with their city hall green roof to reduce heat island effect and storm water management.
Welcome,
As a valued member of the Vectorworks community, we would like to welcome you to this exploration file.
This project documents several common outputs for retail interior design workflows. This project imagines the redesign of an existing store located on a typical UK high street. The file is structured with Design Layers which are associated with building Story levels, as well as Classes to control the graphics outputs and visibilities of objects. Saved Views and Sheets showcase the processes used to create a data driven model, using features such as, record formats, IFC data, data visualizations, and reports.
We suggest running through the Saved Views and Sheet Layers (in the Navigation Palette). You might then explore further via the individual Design Layers. Feel free to adapt any of the resources you find in the Resource Manager.
An accompanying webinar can be accessed from the Vectorworks University - entitled “More Than A Space, Experience Retail Interior”.
The Asharoken House is a 3 story, single-family home located in Northport, NY on Long Island. The site is located on a sand bar overlooking Northport Bay and the site's flat landscape is prone to flooding during severe weather conditions. The home is designed to fit within the fabric of the surrounding neighborhood, where most lots are long and narrow, and the building materials align with a coastal motif.
The project includes a comprehensive 3D BIM model with various elements, such as stories and site details like site modifiers, hardscapes, and other site-specific features, interior furnishings like furniture, countertops, cabinets, and light fixtures, organized by style. Traditional building objects, like walls, windows, doors, and more are organized by styles for consistency.
This sample file is for a corporate event proposed to take place at a convention center. The file includes examples of lighting, rigging, scenic detailing, and staging. There are also several renderings of the project.
The CUBE provides a hybrid and “BIM for landscape” workflow demonstration, showing the process of modelling a landscape in an urban context, using Vectorworks Landmark. Parametric tools, intelligent objects, data handling, and creating associated
views from the integrated plan and model are demonstrated as best practice use, to streamline and optimize the site design and modelling process.
The Urban Park demo file can be used to explore various tools and features found in Vectorworks Landmark such as hardscapes, plants, graphic legends, viewport styles, title blocks, worksheets, and more! Make use of the saved views and sheet layers to explore this file.
The Riverwood Townhomes project file demonstrates Vectorworks Landmark features including plants, landscape areas, site model and massing models. The file also includes hardscape, fence, railing, stair, wall, graphic legends, data tags and worksheets.
The Office Park demo file can be used to explore various tools and features found in Vectorworks Landmark such as plants, hardscapes, landscape areas, graphic legends, viewport styles, and more! It also showcases the ability to import and export Revit files. For instance, the building is a Revit model that has been imported. Make use of the saved views and sheet layers to explore this file.
This sample project shows how Vectorworks can be used to document the scenic and lighting aspects of a theatre tour, in this case the combined production of Macbeth and A Midsummers Night Dream.
The scenic and lighting design is shared for both shows.
The saved views are used to show off specific elements of the design and the sheet layers provide an example of how the paperwork could be prepared to support touring theatrical productions.
