Master the key skills required to be successful in Vectorworks by earning your Vectorworks Core Associate Certification. This learning path contains over 170 courses and exercises that will equip you with the essential knowledge to operate Vectorworks
with confidence. The Vectorworks Core Associate Certification learning path and exam are available free for a limited time.
To earn your certification, you must successfully pass the certification exam, with a score of 80% or higher. There are no restrictions on how many times you can retake the exam. If you do not pass on your first attempt, we recommend reviewing the certification courses and trying again. By passing the Vectorworks Core Certification exam and receiving this certification you will demonstrate to employers and clients that you are
competent in core Vectorworks tools, commands, and workflows.
We highly recommend going through all of the courses in this learning path before taking the exam. However, we know there are many experienced Vectorworks users out there. If you feel you
have already mastered the subjects covered in this learning path, you can skip directly to the exam.
Your certification is valid for 3 years after successfully passing the exam. Once you pass the exam, you will be able to download and display your personal Vectorworks Core Associate certificate and seal. You will be notified 6 months before your certification
expires and with updates for continuing your education.
This learning path is designed to help you get to know Vectorworks Architect and get up and running quickly. We understand that not everyone learns in the same way, so we have provided multiple training options, from instructor-led live seminars and an
on-demand quick start guide, to sample projects for you to explore.
Master the key skills required to be successful in Vectorworks by earning your Vectorworks Core Associate Certification. This learning path contains over 130 instructional videos and exercises that will equip you with the essential knowledge to operate Vectorworks with confidence.
To earn your certification, you must successfully pass the certification exam, with a score of 80% or higher. There are no restrictions on how many times you can retake the exam. If you do not pass on your first attempt, we recommend reviewing the certification courses and trying again. By passing the Vectorworks Core Certification exam and receiving this certification you will demonstrate to employers and clients that you are competent in core Vectorworks tools, commands, and workflows.
We highly recommend going through all of the courses in this learning path before taking the exam. However, we know there are many experienced Vectorworks users out there. If you feel you have already mastered the subjects covered in this learning path, you can skip directly to the exam.
Your certification is valid for 3 years after successfully passing the exam. Once you pass the exam, you will be able to download and display your personal Vectorworks Core Associate certificate and seal. You will be notified 6 months before your certification expires and with updates for continuing your education.
This learning path is designed to help you get to know Vectorworks Design Suite and get up and running quickly. We understand that not everyone learns in the same way, so we have provided multiple training options, from instructor-led live seminars and an
This learning path is designed to help Educational users get to know Vectorworks Design Suite and get up and running quickly. We understand that not everyone learns in the same way, so we have provided multiple training options, from instructor-led live seminars and an
