Skip to main content
Vectorworks University
  • Courses
  • Certifications
  • Dashboard
  • More
Sign In
  1. Home
  2. Courses
  3. Vectorworks, Inc - Global
  4. All Industries
All Industries
Course Languages
Course Language
Course language
All Industries
Elevate Your Experience: What’s New in Vectorworks 2025
Beginner
1h 6m
Start
Explore the latest updates in Vectorworks 2025 designed to boost design efficiency, streamline 3D modelling, and enhance collaboration presented by Jonathan Reeves, an architect, author, and Vectorworks expert. Through real-world project examples, you'll discover how these new features can transform your workflow. Key highlights include Object Visibility, Two Point Perspective, Revit & DWG Collaboration, Room Finishes, and AI Visualisation updates. Reeves will also dive into exciting enhancements in Vectorworks Cloud and much more. Plus, he’ll share extra tips and tricks.
All Industries
All Industries
1h 6m
Beginner
Learning Objectives
  1. Object Visibility
  2. Two Point Perspective
  3. On-Screen View Control
  4. Revit and DWG Collaboration
  5. Room Finishes
  6. Survey Points
  7. Cloud Updates & New Features
  8. AI Visualizer Updates
All Industries
AI Visualizer Patterns and Alpha Channel
Beginner
2m
Start
Added functionality to AI Visualizer, including recall of text prompts, creating seamless pattern images and images with alpha channels.
All Industries
All Industries
2m
Beginner
Learning Objectives
  1. Explore the new AI Visualizer features available with Vectorworks 2025 Update 2.
All Industries
Enhance Your Projects with VR - Vectorworks Odyssey Tool
Intermediate
46m
Start
Join Jazz Hutsby, lighting designer and technician, for an in depth walkthrough of our new Vectorworks Odyssey app for VR headset. He’ll showcase how the app works and give a glimpse of how Odyssey was used in Royal Conservatoire of Scotland production of Sweet Charity.
Entertainment
Entertainment
46m
Intermediate
Learning Objectives
  1. How to add Vectorworks model to Odyssey app.
  2. Understand how to use and benefit from Vectorworks Odyssey.
  3. Sharing your model in Odyssey with anyone - regardless of whether they use Vectorworks.
  4. Discover a real life use of Odyssey app in Royal Conservatoire of Scotland's Sweet Charity case study.
All Industries
Object Level Visibility
Beginner
3m
Start
Show, ghost, hide, or isolate specific objects with individual visibility control. Navigate to specific parts of your model by isolating objects and create custom drawings or viewports to clearly communicate your design intent. Apply object visibility directly within your design layer or save it to viewports and data visualizations. Find fast, flexible workflows, while also working harmoniously with Class and Layer visibilities.
All Industries
All Industries
3m
Beginner
Learning Objectives
  1. Learn about the new Object Level Visibility feature, released with Vectorworks 2025.
All Industries
Vectorworks Cloud Document Reviewer
Beginner
3m
Start
Let project participants view and comment on your document from anywhere on any web-enabled device, getting your projects in front of them faster. Share selected drawings and worksheets and allow collaborators to select areas of interest to access object specifications. They can add comments that you can view within Vectorworks, streamlining your review process. Once you’ve made your changes, quickly share updated documents the same way.
All Industries
All Industries
3m
Beginner
Learning Objectives
  1. Learn about the new Vectorworks Cloud Document Reviewer, released with Vectorworks 2025.
All Industries
Onscreen View Control
Beginner
2m
Start
Discover one-click navigation that allows for easy, instant access to all views of your model and interactive model orbiting with click-dragging. The optional display of XYZ axes, compass direction, and working planes help you effortlessly orient and navigate your model. Easily switch it off with a popover (but you won’t want to).
All Industries
All Industries
2m
Beginner
Learning Objectives
  1. Learn about the new Onscreen View Control introduced with Vectorworks 2025.
All Industries
Two-Point Perspective
Beginner
3m
Start
Produce traditional architectural compositions views with ease using Two-point Perspective mode. Toggled on with a single click, you can work with it directly in design layers or add it to saved views and sheet viewports to provide a clear understanding of a 3D view. Once activated, it stays activated even when you change your view.
All Industries
All Industries
3m
Beginner
Learning Objectives
  1. Learn about the new Two-Point Perspective mode, released with Vectorworks 2025.
All Industries
AI Visualizer
Beginner
5m
AI Visualizer
Start
Combine the strength of Vectorworks with the speed of AI image generation powered by Stable Diffusion. Directly available within the Vectorworks interface, this experimental feature uses Vectorworks Cloud Services for a zero-install, uninterrupted workflow to quickly ideate illustrative concepts or create refined images using your Vectorworks models at any stage of design.
All Industries
All Industries
5m
Beginner
Learning Objectives
  1. Explore the new AI Visualizer released with Vectorworks 2024 Update 4.
All Industries
VECTORWORKS ODYSSEY - VIEWER FOR META QUEST
Beginner
3m
Start
Explore your designs with Vectorworks Odyssey, a virtual reality viewer app created for Meta Quest 2 headsets and beyond. Experience models in immersive VR with bird's-eye view and walkthrough modes. Gain better context for quick and thorough feedback, including cycling through design options with access to design layer visibilities.
All Industries
All Industries
3m
Beginner
Learning Objectives
  1. Explore the new Vectorworks Odyssey viewer for Meta Quest 2 headsets, released with Vectorworks 2024 Update 4.
All Industries
CONNECTING TO A DATABASE
Intermediate
15m
Start
In this course, we'll learn how to connect an external database to the records in our drawing. Using SQLite as a database source, we'll quickly fill our records with data without having to manually retype anything.
All Industries
All Industries
15m
Intermediate
Learning Objectives
  1. Explore the Database commands and tools.
  2. Connect an external SQL database to our existing records.
  3. Transfer our data back and forth between our model and the external database.
All Industries
3D MODELING SHOWCASE IN VECTORWORKS FUNDAMENTALS
Beginner
40m
Start
Join us to see how four Vectorworks 3D modeling experts create their projects in Vectorworks Fundamentals. They’ll showcase some of the many versatile tools and workflows of the software to design and showcase their projects.
Come see the power of solid, subdivision, and NURBS modeling, surface arrays, rendering and lighting techniques, and much more.
All Industries
All Industries
40m
Beginner
Learning Objectives
  1. Identify the various 3D modeling technologies and techniques in Vectorworks Fundamentals.
  2. Recognize the extensive file import and export options available in Fundamentals including avenues to 3D printing and other fabrication.
  3. Discuss the process of modeling your work and creating its associated 2D drawings.
  4. Describe the range of rendering styles available to depict and present your project.
All Industries
GRAPHIC LEGEND ADVANCED SETTINGS
Beginner
3m
Start
Enhance your workflow with a better way to create custom graphic legends. It’s now easier to align, scale, and alter the dimension of images as well as customize dynamic text. You’ll also be able to preview changes in sorting and class visibility.
All Industries
All Industries
3m
Beginner
Learning Objectives
  1. Learn about the improvements to Graphic Legends in Vectorworks 2024.
  • 1 Page 1
  • 2 Page 2
  • 3 Page 3
  • 4 Page 4
  • 5 Page 5
  • » Next page
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
DID YOU KNOW?
Auto Enroll
AI Visualizer
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
Auto Enroll
3D DRAGGER - INTERACTIVE RESHAPING
Auto Enroll
EXCEL REFERENCING
Auto Enroll
VIEWPORT STYLES
Auto Enroll
SHADED RENDERING SHADOWS AND CAMERA EFFECTS
Auto Enroll
UI MODERNIZATION
Auto Enroll
PHOTOGRAMMETRY & POINT CLOUDS WITH THE NOMAD APP
Auto Enroll
USD IMPORT AND EXPORT
Auto Enroll
  • 1 Page 1
  • 2 Page 2
  • 3 Page 3
  • 4 Page 4
  • 5 Page 5
  • » Next page
Vectorworks, Inc
Privacy | Contact Us
Powered by Moodle Workplace
